Awful Noise-Case of the Monday's
Try "belt dressing", its a spray on belt lube. It usually fixes noises like that. You can get it at any auto parts store.
If it's only a temp fix, it's likely a bearing going out on a idler pully (such as the alt. bearing, ilder, ac compressor, or ps pump). Usually you need to replace the entire compoent and not just the bearing though, so that sucks. It's also a sign of the compoent ready to break.
Well, took it to Grandview-- after a 3,800 dollar quote that included a new steering rack, struts, and other "goodies" I gave them the middle finger with my mind and walked away. The fact that he finished the bad news with a "oh, yea might as well throw some new tires on there while its on the lift" let me with a bad taste in my mouth.
I've got my independent coming tonight for a second look. I'll let you know how it goes. Thanks guys.
probably the same nasty noise my starter just started making the other day. Just pulled it and applied some grease. Havent got to put it back together since im doing a few other things while im in there
jonesy29
02-04-2010 10:23 AM
