Auto transmission fluid capacity
Old 06-07-2013 | 09:59 PM
jimboesfo's Avatar
Default Auto transmission fluid capacity
Just did the automatic transmission fluid and filter change on the TT per the Bentley manual procedure. Measured 4 liters during the drain and 4 liters during the fill. Just wondering if that is what others see during the change. The kit from Blaufergnugen included 6 liters and the DIY for the A4 Tiptronic indicates it should be 5.5 liters. I realize that the pans are different so there is no reason that they should have the same fill amounts. Also, does anyone know the fluid capacity of the transmission? I did try to find it using search but found no specific information.
Old 06-10-2013 | 05:46 PM
jimboesfo's Avatar
According to the Bentley manual, the capacity of the 09G transmission used in the FWD TT is 7.0 liters. Still interested in others experience with drain/fill amounts.
Old 06-30-2013 | 01:08 PM
Clrwatrtom's Avatar
the pan in my tt held 2 litrs when i had to drop it this week to remove the driver's side front control arm mounting bolt. That would indicate to me that the torque converter holds 5 litres is the above mentioned amount is correct. i believe you have to slightly overfill it cold, bring it up to a certain temperature, remove the inspection bold and let the exess drain off until it just drips and replace the inspection bolt. Oh, if only they had dipsticks!
mrk3cobra
09-23-2012 01:59 PM
pbrules10
07-03-2011 02:55 PM
crazyone
05-15-2011 12:38 PM
perryal
05-31-2010 10:24 AM
balkranjit
05-18-2008 03:00 PM
