Audi TT225 WTF....
Audi TT225 WTF....
Ok guy here it is this is my first audi. I bought an audi tt225 2001 about 2 weeks ago form my local dealer. Im normal a vw guy and this is my first trip down the audi runway. I have had so many issue with this car sence i bought it. And i have spent hours on the internet researching and have just decioed to get call a newb and ask.
1 - My temp gaguge when i stop and it is warmer than 65 degrees out goes form the center mark to the next line where is sits till i start moving again. The deal has replaced the cencer i had a black now i have a green one did nto fix it.
2 - No matter what my CEL comes on for a secondary air inject system pump or something the dela has test and it pass all the test but sure enough after a day the CEL come back on.
3 - The worst of all after any highway driving when i get off the high way my car has limited or no boost. Im guessing it is soft limp mood but there is never a CEL for it. The only way have been about to get the car to boost again is to disconect the negative battercable for a little while and plug it back in.
Please help me guys i realy love this car and would be so happy to drive it if i can just get the bugs worked out of it and start upgrading it.
Thanks in advance,
David
Thanks in advance,
David
RE: Audi TT225 WTF....
Most likely the thermostat thats making the temp gauge climb. How many miles on the car? 60K is the cutoff before you start playing russian roulette with your timing belt, and the water pump is probably on its way out as well. (the plastic impellers crack).
Can't really say on the secondary air, the exact code would be helpful.
Limp can come on for a bunch of reasons, but you'll probably see a code for everything. Are you checking for a code when you notice its underpowered? Don't shut the car off, some funky stuff is hard to track if you shut the car off and give it a chance to reset itself.
Well the car only have 31000 miles on it. And after i tune the car off it still in limp mode and does not boost only after i disconnect the battery doe sit boost agian. Maybe the n75 going bad the service records show the DV was replaced not to long ago. I would say becasue i ca get my boost back by disconnecting my battery that is is an electrical issue but im not sure becasue there is no CEL just no boost. The only CEL that ever comes up is for the secondary air pump injection system which im pretty sure is just for emissions. Can a bad o2 cencer cause the CEl and the car to go into limp mood after doing some high way driving
Sitting still and having the temp climb to that mark is actually quite common. This alarmed me as well when I first got the car. While sitting at long lights I could see the temps climb. It only happens to me in 70+ weather. Usually I am at the tick mark before the half. After a spirited drive it sticks around the half way mark. It does sound like you are hitting limp....
You're gonna get screwed hard.
You're being too nice to the dealer.
If they can't fix it, tell them you DO NOT want the car.
The more chances you give them and the longer you wait the harder it will be for you.
Tell the dealer to eat it.
temp gauge should be at 12 o'clock pretty much all the time once the car is warmed up. The thermostat that comes with the dieselgeek kit at least.. isn't quite the quality I'd like, it takes a bit longer to adjust than the ones that come in the car. (can't remember who makes what).
ORIGINAL: achTTung
ORIGINAL: achTTung
ORIGINAL: Mobius97
I completely disagree. I have read on numerous posts of different owners who's temp guage acts this way. They consistently state that the gauge will go to the next tick past halfway when waiting at a light for sometime or idling for a small bit. I do not have this trouble in the colder months but the one summer since I have had the car this was the normal behaviour. It would always go back down when I started moving and getting airflow to the radiator again. I am only speaking in reference to the stock thermostat.
