ARS????
RE: ARS????
ORIGINAL: TurboToughTT
Yeah it has Bose, yeah i saw it was asr when i got in after i posted it, if i turn it off my tires will spin better?
RE: ARS????
ORIGINAL: Vorais
The answer to this is basically yes. What happens when ASR is on is that it checks to see if your tires are breaking loose. If it has already adjusted the 20% power to the rear tires and still notices wheel slippage it will apply braking power to regain tire control. This is done very quickly and has saved many people from slidding off the road while cornering. The issue with this is that if the tire slipping was done under some control then you are actually robbing the car of power. It makes the car safer but a tad slower in the acceleration/handling department.
