APR K04 kit fit on my car?
I mailed Apr people that APR K04 kit is gonna fit on my car, but never got replied back.
http://www.goapr.com/products/tvk04.html\
Is that engine code matter?
I have 2000 AUDI TT 180 HP FWD ATC engine code.
help me plz...
help me plz...
Thx
Thx, what did u bought other fun stuff?
and... what custom turbo kit u talking about?
I was looking for Kinetic 1.8T Big Turbo Kit, but it was too much problem for
me bc to have bigger turbo i need new rod, fmic, ecu software, fueling etc..
(cost me too much money...)
Thx CincyTT
what do u mean by same tune as AWD golf?
like.. 4bar FPR / 3" Map ?
I know K04-001 is not worth it, but that's just fit for me i guess... since my k03s is completely gone now...
The AWD is basically the same ecu as the ATC. meaning if they can do one, they should be able to do the other. Not sure what they use for fueling. Plus, if you have a 2000, you have a ko3, just find a used ko3s for just over $100 and install that. No tuning needed
What are the options for a k04 on a 2000 ATC TTQC ?
Yes, all 00-01 ATC motors have a ko3
The ko4 is only rated 5hp more than a ko3s. The gains wont be huge swapping to either, maybe 5-10whp. Only way your are going to see more power is straining the turbo by running way to much psi (23-26psi) or increasing the timing. The ecu can adjust for the minor change in flow at the same psi
Wouldn't the K04 be a direct bolt-in swap for the K03? I thought it was and requires no additional tuning if used stock and at the same boost..? Also, wouldn't this leave you set up for increased power later (however small) when you do want to chip it and/or increase boost due to the K04 being bigger?
