apexi turbo timer
RE: apexi turbo timer
yup i got it and two of the features like 02 sensor or A/f ratio don't work because the way the car's electrical system works you can make them work but you basically rewire some parts of the system. (the battery voltage works though) But yes i like the way it works, but if you can wait in your car for like 2 minutes its the same thing i like the way it looks and i dont have to wait in my car to let it cool down. BTW u can't use the keyless entry u have to manually put the key in ther door and lock the car while the turbo timer is counting down.
both don't need turbo timers unless you intend driving them hard on track days when the car needs to idle to help cool the turbo because of hard driving, anything that shows o2 sensor readings and air flow I would call a systems monitor not a turbo timer
where did u hear that? the turbo timer keeps the engine running after you take the key in the ignition so....no the 225 doesnt already have this and i would get one if you dont like waiting in your car after your turn the key
