Any mechanics around?
So I was quoted 22 hours at 90 bucks an hour to install the following:
Turbo(10 hours)
Coilovers(5 hours with alignment)
Snow Performance Water/Meth(5 hours)
Dogbone Mounts/Boost Gauge/FPR/Injectors(2 hours)
So I'd be looking at 2000 bucks to install that. Sounds a little high to me. What do you guys think?
[align=left] [/align]
Turbo(10 hours)
RE: Any mechanics around?
Is that at a dealer?
Find an independent shop for cheaper hourly, and more realistic time charges.
Better yet, do everything except the alignment yourself, and put the money towards tools so you can do it free next time.
No better time to learn than when you have a $2000 worth of motivation staring at you.
ORIGINAL: RedTTQ
Turbo(10 hours) Done in less than 4-5hrs
Coilovers(5 hours with alignment) Havent done it but probably 3-4hrs and then $60-80 for alignment
Snow Performance Water/Meth(5 hours) Sure its less.
Dogbone Mounts/Boost Gauge/FPR/Injectors(2 hours) All in all thats about right, but anyone can do those.
If you want help, i and the forum can help you. All but the coilovers are a easy job. Those are doable, but i wouldnt mess w/ suspension if your not sure what your doing
I found the coilovers a pretty easy job to do, you can do them with your basic set of tools plus a pry bar and spring compressor(can be rented at autozone) and air tools make it a lot easier also. ans yeah 3-4 hours is about what it took me(working by myself and have never done coilovers before)
and btw, most of us here can be considered mechanics
ORIGINAL: cincyTT
ORIGINAL: RedTTQ
ORIGINAL: RedTTQ
I just called my friend who works at a place that does suspension and he's gonna get them installed for me at a slightly discounted rate at 65 an hour for 4 hours. Saves me 190 bucks.
I would suggest you buy an impact wrench, as I found lots of stuck bolts on my tt. Otherwise, the basic sockets, torque wrench, slide hammer, hex and torx sockets, ect would be ideal (but you could prob make do with less).
ORIGINAL: RedTTQ
I suppose I could go buy some jackstands and do this at my dads this weekend. I'm not very experienced though. Will I need special tools?
ORIGINAL: cincyTT
Only the coilovers require special tools. Everything else can be done with handtools. The turbo, dogbone, boost gauge, and injectors (not sure why you need those) will be easy. The w/m kit willbe a little more challenging
ORIGINAL: RedTTQ
