anti-seize ok for lug/studs?
Old 10-07-2007 | 01:48 AM
DBK123's Avatar
Default anti-seize ok for lug/studs?
"I've found that a tad of anti-seize compound on the studs makes life a whole lot easier for subsequent changes. I do it for all my cars, trailers etc. "Just a dab will do ya". Maybe that slogan dates this ole' fart."
"Once you have completed your test fit, we suggest removing the wheel and applying a thin coating of "antiseize" around the axle hubs to help prevent rust and permit easier removal when it's time to rotate your tires. Do not apply "antiseize" to the lug hardware or studs." The Tire Rack
Who is right here? Where is it ok to dab anti-seize?
Old 10-07-2007 | 02:04 AM
eliTTe's Avatar
Default RE: anti-seize ok for lug/studs?
I use it... it will suck if you don't... unless you take your whells off every week or so.
Old 10-07-2007 | 09:27 AM
quattro411's Avatar
yup, works great
Old 10-07-2007 | 09:44 AM
cincyTT's Avatar
I'm make believe
sparkplugs have to use it and same with o2 sensors. Some places just makes life easier if you need to remove it. That is except for places that need lock-tite
Old 10-07-2007 | 10:19 AM
DBK123's Avatar
Yes but if you put it directly on the lugs or nut will you need more torque to tighten sufficiently to prevent loosening???
Old 10-07-2007 | 10:56 AM
cincyTT's Avatar
I'm make believe
No, you would tighten them the same. Just remember that anytime you stick something steel in aluminum, you need antiseize, or things that see alot of heat and you want to remove at some point.
colony777
12-04-2010 09:55 PM
cwedholm1
10-19-2009 10:50 PM
SVT21
05-08-2009 02:24 PM
theguy1084
08-19-2007 11:15 PM
carguytt987
04-03-2007 01:09 PM
