airbag light / headrest?
Old 02-27-2007, 02:22 AM
Dana Reed's Avatar
Default airbag light / headrest?
This may seem like a silly question, but with all this complex German engineering, you never know. I needed a leather sample for a dye kit so I took my seat out. Nothing to spare underneath with all the complicated stuff down there, so I figured I'll, just send my headrest as a sample (toLeathermagic). I put the seat back, connected all 3 plugs, and now the airbag light is on. Is there possibly any interconnect with the headrest that could cause this? All the other electronics work flawlessly (knock on wood).
Old 02-27-2007, 03:57 AM
auditech79's Avatar
Default RE: airbag light / headrest?
If you took out the seat and had the key on you would set a fault for the airbag on the side of the seat, You should be able to see writing on the outer side bolster on the seat that says airbag. If you have or know someone with a scan tool you can erase the fault and it shouln't come back on. Next time you remove the seat make sure you don't cycle the key, the connector for the airbag is the yellow one under the seat.
Old 02-27-2007, 12:37 PM
diehlryan's Avatar
you can probably unhook the battery for 15-20mins to clear the CEL.
Old 02-27-2007, 07:28 PM
ouTTie914's Avatar
Don't disconnect the battery unless you have your radio code!!!
Wouldn't want to put your radio into safe mode!
Old 02-27-2007, 07:34 PM
diehlryan's Avatar
ORIGINAL: ouTTie914
My radio REFUSES to go into safe mode so I always forget about that. I even have the code. I feel left out. [&:]
Good looking out Becca. [sm=drlove.gif]
Old 02-27-2007, 07:38 PM
ouTTie914's Avatar
Hey Ryan where's that new pic of your car... I'm bored, and want to make a sig!
Old 02-27-2007, 07:44 PM
remove the ground wire from the battery for 10 seconds then replace this resets the airbag light
if it stays on you have a problem
Old 02-27-2007, 07:48 PM
diehlryan's Avatar
Its soo dirty right now. Its not worthy of any pictures right now.
Old 02-27-2007, 07:53 PM
ouTTie914's Avatar
ORIGINAL: diehlryan
Dirty?!? I don't understand?
It's 39* here, just got about 6 inches of snow yesterday, and well my car is shiny (No it's not garaged)!
Old 02-27-2007, 07:56 PM
diehlryan's Avatar
here.. i just snapped one. its not worth washing the car right now w/ warm weather, wet roads, and salt everywhere.
no comments because its not clean please!
Quick Reply: airbag light / headrest?
