Air/Fuel control
Old 09-26-2007 | 03:06 PM
ooantipostoo's Avatar
Default Air/Fuel control
My question is could I just use a AFC II to control my new injectors without getting the car chipped by using the diode mod?
Old 09-26-2007 | 03:11 PM
cincyTT's Avatar
I'm make believe
Default RE: Air/Fuel control
Yes and No, you can do some things with that, but then you then cant use things like lemmi. ALso the ecu doesnt always get along with it. If you have a 2000, it may work some, 01+ no, not even worth trying. Send Jeff on here a pm and asked him about his experience with it on his a4.
Old 09-26-2007 | 03:12 PM
Great thanks for the input... Also forgot to mention this would be with the big turbo kit on. I was just going to pick on up to make my car run for maybe another month till i could purchase the chip. Revo sells RC550 files right.
Old 09-26-2007 | 03:16 PM
cincyTT's Avatar
I'm make believe
If you plan on putting the turbo on BEFORE the chip, its better to jsut run low boost and use stock fueling. THEN when you get a chip install the injectors and chip (Yes, revo sells the 550file)
Old 09-26-2007 | 03:51 PM
So you would say dont even worry about getting a AFC ?
Old 09-26-2007 | 03:57 PM
cincyTT's Avatar
I'm make believe
Old 09-27-2007 | 11:12 PM
Krissrock's Avatar
yeah don't bother if you're getting chip cause you can't use both...and BTW, APEXi makes the AFC SELECT for euro cars....I have one, and will work with no probs
funpilot
06-01-2010 10:42 AM
driftking8732
07-09-2008 06:25 PM
ljzrelak
04-05-2008 11:14 PM
ARIaudiS4
10-18-2007 07:11 PM
wienerwate
03-07-2005 12:43 PM
