AFR Logging?
Old 05-31-2010, 06:46 PM
MCPaudiTT's Avatar
Originally Posted by jonbonazza
Wait... Some of the newer cars come factory with a wideband??? That's awsome! When did the TT start using a Wideband from the factory?
BEA engine code.
Old 05-31-2010, 07:08 PM
cincyTT's Avatar
I'm make believe
Originally Posted by rpetral0
hmm...so keep running what it already has? I've put it back to how it should be with the OCT from when Kiva had it. No more blow off, back to hyperboost, fixed up the modshack intake, various other things. Any other recommendations until i have the money to do a turbo? MBC? or scrap that to...As of right now I took that out and i'm running the stock N75 which is what the guys at stratmosphere suggested.
I wouldnt change the tune. What do you mean you fixed the intake? Hope you didnt put that stupid cover back on it... Make sure everything is running right and save your funds for a real turbo setup and motor rebuild
oh, and timing belt, tie rods, ball joints, exhaust, crank case vent lines, p/s lines, and haldex fluid/filter change are all being done wednesday...yeah car was a mess haha. Not to mention i believe it might be in need of a clutch soon.
If i remember right, that car has close to 200k miles on it now. All that crap has to be a mess.
180's got it in 01 with the AWP engine code
225's got it in 03 with the BEA engine code
Old 05-31-2010, 08:17 PM
rpetral0's Avatar
nope, 97K. It's not to bad just bits and pieces here and there. Cleaned up nicely and I only have that list of stuff left to go, really a nice car especially for the cash. Just planning on getting everything up to par and then over the next year save some cash and do a motor/turbo build based off of your write up actually. So props and thank you for taking the time to write it up! Can't really decide between k04 and gt28rs though...I'm thinking about posting up and getting some opinions as well as see some results from others I guess.
A4Cragman
B7 Models
03-12-2014 01:00 PM
ImTheDevil
03-12-2008 11:43 PM
CoastalA4
07-30-2007 09:03 AM
akielb
03-01-2007 01:27 AM
AudiTurbo
09-17-2006 04:54 PM
Quick Reply: AFR Logging?
