adjusting idle
Old 09-18-2007 | 06:42 PM
PCBOI808@HOTMAIL.COM's Avatar
Default adjusting idle
is the only way to adjust the rpm w/ecu?
Old 09-18-2007 | 07:14 PM
diehlryan's Avatar
Default RE: adjusting idle
yes.. through lemminwinks or unitronic software i believe.
Old 09-18-2007 | 08:29 PM
cincyTT's Avatar
I'm make believe
From what i heard is that lemmi can only move it 200rpms or so, but the dealer should be able to increase it more if need be
Old 09-18-2007 | 09:00 PM
diehlryan's Avatar
ORIGINAL: cincyTT
Ray (rayveedub) just increased mine by 250.. i think I remember him calling it unitronic software or something like that. maybe he'll read this and chime in.
Old 09-18-2007 | 09:34 PM
cincyTT's Avatar
I'm make believe
its the unisetting, unitronics version of lemmingwinks.
Old 09-19-2007 | 12:42 AM
themysteryman83's Avatar
I was able to do it through vag-com. Engine,Basic setting, channel 1, value 128 is normal idle @ 760rpm iirc. 1value moves in 10rpm increments. Good way to get rid of the shudder from the low idle. Someone please correct me if i'm wrong.
Old 09-19-2007 | 11:56 AM
cincyTT's Avatar
I'm make believe
Your right, its a good way to get rid of vibrations from clutches and stiffer mounts
Old 09-19-2007 | 12:00 PM
off the audi subjuct this a RICER ques.
my friend has a 98 integra is anyone on here no if the only way to adjust the idle is with the ecu ?
Old 09-19-2007 | 12:08 PM
cincyTT's Avatar
I'm make believe
You can adjust a b-series engine manually, but i dont know how, just seen it done from a distance.
tahoehtp
05-20-2009 02:06 PM
nrowensby
06-04-2008 09:57 PM
Skipponator
12-17-2007 02:36 PM
Lopster99
05-01-2007 11:00 PM
rons01a4
04-27-2006 12:25 AM
