8000k HID BULBS INSTALL?
Old 09-07-2007 | 08:27 AM
vivanov1's Avatar
Default 8000k HID BULBS INSTALL?
since the bulbs are xenon, i assume i can just upgrade the bulbs to a bluer color such as 8000k. is it easy to swap out the light bulbs or the bumper must be dropped? i havent picked up the car yet so i dont know? thanks
Old 09-07-2007 | 11:17 AM
moeron7's Avatar
Default RE: 8000k HID BULBS INSTALL?
I'm pretty sure you can change them from inside the engine bay. I dont know if they are compatible or not.
Old 09-07-2007 | 11:25 AM
Wintermute's Avatar
Is this too bright? Wouldn't it melt your housing?
Old 09-07-2007 | 11:32 AM
moeron7's Avatar
I thought xenons rancooler so it wouldnt melt your housing. I'd go 10k if you could, they look sweet!
Old 09-07-2007 | 12:23 PM
cincyTT's Avatar
I'm make believe
The 8000k will be less luminous than the stock lights. 6000k is the brightest/cleanest. Also, heat shouldnt change, its the differnt kelvin level that determines the color
Old 09-07-2007 | 12:27 PM
techbod's Avatar
Servicing headlights - Gas-discharge headlights[/align]Exploded view[/align]Note:
If measures are taken which could affect headlight setting, headlights are to be re-adjusted.
1. Headlight housing
â—†As of approx. 04.00, igniter for gas-discharge lamp -J343 (left) or -J344 (right) is attached directly to headlight housing [/ul]
2. Fog light bulb
â—†H3 - 12 V, 55 W
â—†Bulb replacement [/ul][/ul]
3. Side light bulb
â—†H6 - 12 V, 6 W
4. Main beam bulb
â—†H7 - 12 V, 55 W
5. Bulb holder
â—†For main beam
â—†With holder for side light bulb [/ul]
6. Housing cover
â—†With seal
â—†For fog light [/ul]
7. Housing cover
â—†With seal
â—†For main and dipped beam [/ul][/ul]
8. Bulb holder
9. Turn signal indicator bulb
â—†H12 - 12 V, 21 W
10. Retaining ring
â—†For gas-discharge lamp [/ul]
11. Gas-discharge lamp
â—†35 W, D2S
[IMG]local://upfiles/12092/8DA2D4601A7E4D1D9EA49E761FE68509.jpg[/IMG]
Old 09-07-2007 | 12:30 PM
cincyTT's Avatar
I'm make believe
Dave you really need to send me a copy of that sw [sm=goodidea.gif]
Old 09-07-2007 | 01:06 PM
moeron7's Avatar
ORIGINAL: cincyTT
Yeah no joke! Is the side light bulb (#3) the bulb that is in the bottom reflector that stays on when the lights are on?
Old 09-07-2007 | 01:11 PM
cincyTT's Avatar
I'm make believe
#9 is the light in the yellow reflector
Old 09-07-2007 | 01:18 PM
Wintermute's Avatar
ORIGINAL: cincyTT
What level of light am I thinking of that will melt the housing? I always thought anything over 6k would be to hot.
