42dd and forge007 install...
Old 08-14-2008 | 10:20 PM
THEPARTSMAN10's Avatar
Default 42dd and forge007 install...
anyone have links for the installs please? need some help.
Old 08-14-2008 | 10:31 PM
.clipse's Avatar
SoCal Crew Member
the forge DV is a real simple install. look for the stock DV and put in the forge DV in place with all the corresponding hoses.
kind of like a replacement. all youll need is a phillips head screw driver.
well anyways, here's the install guide:
http://www.forgemotorsport.com/valve.pdf
Old 08-14-2008 | 10:34 PM
i heard you have to do it in reverse or something....and also it came with different springs...with all the mods i have listed, what spring should i put in...im getting it chipped here in about 2 weeks..will i have to change the spring or what?
Old 08-14-2008 | 10:56 PM
cincyTT's Avatar
I'm make believe
Keep dv installed like stock
green spring now, add a shim or two when chipped or you can swap to the yellow (most like green + 2 shims)
Elittes how to - http://forums.vwvortex.com/zerothread?id=3291772 Hope you have a sawzall handy, otherwise it will take awhile
Old 08-14-2008 | 11:07 PM
ok that write up was good. two questions...it shows nowhere where the gaskets it came with go...and also...do i need to install o2 sensor spacers if i am going to get it chipped here in a couple weeks?
Old 08-14-2008 | 11:11 PM
cincyTT's Avatar
I'm make believe
The gaskets only go in one place, pretty simple. BTW, i dont use any on my dp since they just blow out and then i have a leak. The spacer is for not having a cat, you wont need to do that if you run a cat or have a catless file from the chip tune
Old 08-14-2008 | 11:14 PM
it is a catless downpipe. if im going to get an apr 93 tune...will i need spacer?
Old 08-14-2008 | 11:17 PM
cincyTT's Avatar
I'm make believe
I think they have a catless/test pipe file, but i would ask the place chipping your car for certian. If not, you will need the spacer otherwise you will get a cel after about 100mi. I still need one for myself, but i dont know what i would do w/o a cel since its been on for so long LOL
Old 08-14-2008 | 11:23 PM
lok, im just going to install it with no spacers then. havent decided on chip tuning place yet anyway...apr..giac..revo.. but install the dv with a green spring...then after chipped..put two spacers in? they come with it? i didnt even open it lol
Old 08-14-2008 | 11:25 PM
cincyTT's Avatar
I'm make believe
The tuning kit should have 2 spacers and 3 other springs. I wouldnt worry about the spacer then if you still havent picked a tuner yet. Just make sure you use plenty of antiseize on the threads of the o2's so you can replace them if needed or add in the spacer
Quick Reply: 42dd and forge007 install...
