42DD 3" dp, 19mm Rsb on the way~
Old 01-05-2008 | 01:07 AM
gTT's Avatar
gTT
Default RE: 42DD 3" dp, 19mm Rsb on the way~
ORIGINAL: tom1222
ORIGINAL: gTT
I read from the forum that people suggested 19mm will be enough for the RSB if i will keep the stock front. (on quattro)
I will try to install the R1 this weekend and will let you know the result. I hope it will improve the boost.
My boost will not pass the 10, but vacuum at 19 when idle at normal temp.
Sounds like you either have a boost leak or are in limp mode. Or if you are still running the stock DV then the diaphram might be ruptured.
Do you hear any whistle sounds at accelleration? Let us know how the R1 works out. It should be about a 5 minute swap and should gain
you instant results.
i hope i am not in limp mode~ I couldn't do the installation this weekend, cuz the flooding in bay area. hopefully the rain storm will end soon. Also my rsb came in today~ yea~
4mymalamute
03-08-2009 03:15 AM
dale55
05-13-2008 10:35 PM
wood_e
09-24-2007 09:39 PM
laboomba
08-02-2007 11:01 PM
luvin_the_rings
11-20-2006 04:08 PM
Quick Reply: 42DD 3" dp, 19mm Rsb on the way~
