300bhp in a 225 Quattro
RE: 300bhp in a 225 Quattro
Well the ARP chip tune says 263hp/267lb-ft
So if you added Borla Exhuast which i would guess you could get an extra 10hp out of.
Neuspeed intake which is another 10ish if your luck.
Thats 283hp
If you did a big FMIC and could get your temps down i would bet you could get into the 290HP range.
But i've never seen all this stuff on the dyno before.
Thats 283hp
ORIGINAL: BlackRaptor
Thats 283hp
Thats 283hp
Isnt the APR spec 263 to the flywheel? I didn't think that was to the wheels. My shop here told me with the APR tune (which I had done on Tuesday), i'm prolly getting around 190whp.
ORIGINAL: RAUDITT
Is it possible to make 300hp at the wheels without a Major upgrade such as Stage III turbo? Someone mentioned an ATP eliminator kit is a good start. What do you guys think?
I hope to dyno my car soon, when i get the Forge FMIC and I am thinking of putting DEI's Cry02 system in my car, hopefully that with a few upgrades I hope to hit 300whp. Hopefully... but dyno results from what I have so far are soon to come...
ORIGINAL: 225tt
ORIGINAL: XCLR8TT
No way are you going to hit 300 whp without a big turbo upgrade. Remember your 225 is flywheel hp not at the wheels. There is about a 20% loss through the AWD system down to the wheels.
ORIGINAL: 225tt
ORIGINAL: 225tt
So in theory if you can get to 360 crank hp then you will be at 300whp? 20% loss? That sounds kind of high, is there any place where this can be looked up with dynos and numbers?
