225TT REAREND NOISE
Old 02-28-2007, 01:30 PM
spyderconv1999's Avatar
Default 225TT REAREND NOISE
Can someone help me with how much noise the rearend of a TT makes while driving ive got 42k on mine and i have only had it for about a month and it just dont seem right to me, its like a humm i guess
Old 02-28-2007, 02:13 PM
Default RE: 225TT REAREND NOISE
can someone help me with what fluid is recommended in the rear diff
Old 02-28-2007, 02:50 PM
MeanAudiA6's Avatar
OEM Rear Axle Fluid (G052145S2) its on ecstuning.com under the maintence tab
Old 02-28-2007, 03:47 PM
.clipse's Avatar
SoCal Crew Member
will that clear up the rear end axle knocks?
Old 03-01-2007, 09:39 AM
225tt's Avatar
rear end knocks?? dosent sound good
Old 03-01-2007, 03:46 PM
Quattro Libre's Avatar
Sorry to jack, but same car and same issue (rear end noise) except mine is creaking... Any suggestions?
Old 03-01-2007, 04:11 PM
.clipse's Avatar
SoCal Crew Member
did a little searching around the forums... seems to be common. i think it's the fuel pump just doing its job~
Old 03-01-2007, 04:17 PM
I think i have a bad bearing in the rear diff.....but not sure
Old 03-01-2007, 05:09 PM
MeanAudiA6's Avatar
check struts and bushings in the rear they might just need to be greased
Old 03-01-2007, 05:25 PM
NO dont think, its more like a humming/whining noise, not a clunk, its like a bad wheel bearing noise comming from the rear diff
Quick Reply: 225TT REAREND NOISE
