2004 225 Coupe - Read CD Changer
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
All I can tell you is that the most common cause is the CD changer itself has failed. It is possible there is a wiring problem (open, short, etc) but that's very rare. You should check for power and ground at the changer, and continuity of the other wires from the changer to the radio first, just to be sure.
You can do sort of a quick check by doing the following:
turn the radio off
press and hold the MODE button and turn the radio on
realease the MODE button
If it says "CONNECT" and "CD", the wiring is OK
If it says "NO CDC" it could be a possible wiring problem (a bad CD changer will show the same NO CDC message also)
turn the radio off
formulagigi
02-21-2008 09:24 AM
