2002 TT engine light after throttle body cleaning
so my RMP was Idling rough, i read if you clean the throttle body, it will fix the issue, so i opened it up the throttle body and cleaned it, it was super dirty, now my idle is perfect, but now, my engine light comes on and my turbo is acting up, not kicking in etc.
anyone have a clue what this could be? my turbo seems to work fine as i hear the whistle when warming up car, anyone any clue?
thanks
thanks
Do a throttle body re learn, if u moved the butterfly with the car off u probably threw it out of calibration, our throttle bodies are touchy. I'd do that before I touched anything else, a local shop might have the software to do it, or if u have vag com can do a relearn,
thanks for the reply,
so i found a very nice individual that has a vag.com
but he needs to know what code i need to do or what process is used to relearn the throttle body ( throttle body adapatation ) would you know what steps is needed for this?
ive never used a vagcom and he also does not know what the step is for the relearn, any idea? thanks again for your help
