2001 TT 225 - Creaking Suspension (Conclusions)!
Old 05-30-2007 | 03:38 PM
superreverb's Avatar
Default 2001 TT 225 - Creaking Suspension (Conclusions)!
I bought my mother's 2001 Audi TT 225 and she failed to mention a host of issues. I love the car, but have to get these bugs worked out!
I first had to address the convertible sensor that went bad..... $400!!
Now I've been noticing the creaking front right suspension. Also, I'mhearing asoft clunk when turning the wheel fully one direction or another when backing out..
I've done my homework on the web and have come to the following conclusions (based upon web info):
Creaking Issue part replacements:
[ul][*]Sway bar[*]Stabilizer bar (is this same as sway?)[*]Bushings[/ul]
Steering knock:
[ul][*]Strut mount[*]Strut bearings[*]Tie rod ends[/ul]
Is this the general consensus on these problems or am I missing some things? I'm an Audi newbie, so any help is greatly appreciated!
Thanks!!
Old 05-30-2007 | 03:43 PM
diehlryan's Avatar
Default RE: 2001 TT 225 - Creaking Suspension (Conclusions)!
steering clunk could be CV joint.
Old 05-30-2007 | 04:02 PM
ouTTie914's Avatar
Flush your power steering fluid first. It's a cheap DIY, and fixed it for me. I had a horrible creaking at low speeds, while turning my wheel as well.
Old 05-30-2007 | 04:19 PM
neur0tic's Avatar
HA!
I have horrible suspension creaking! Unfortunately, I haven't found the fix yet. Im guessing corroded control arms, old bushings ( on mine at least). I've actually gotten uderneath and those control arms look 30 yrs old. lol
Old 05-30-2007 | 04:23 PM
Indiepunk's Avatar
I put in the Upper Strut Kit fromECS Tuning hoping it would eliminate the creaking while turningat low speeds. It was not the source of the problem. Still creaking.
Old 05-30-2007 | 04:37 PM
neur0tic's Avatar
Mine sounds like an old bed when I go over speed bumps. lol
Old 05-30-2007 | 04:44 PM
moeron7's Avatar
ORIGINAL: neur0tic
Yes thats what mine sounds like too. If anybody know what the fix is please tell me!
Old 05-30-2007 | 05:05 PM
achTTung's Avatar
That clunk might just be a little driveline bind. Only happen when you're backing up? Thats usually when I would hear it. Not much you can do about it if thats the case. Maybe quit backing up? ; )
Old 05-30-2007 | 05:31 PM
diehlryan's Avatar
dont the bushings on the front sway bar go bad and make a creaking noise?
i remember seeing a tech bulletin on this.
Old 05-30-2007 | 05:43 PM
Damn, you figure dealerships would know exactly what the problems are. It's the same w/ water. When it's wet out, the suspension makes no noise.
I'm going to start calling random dealerships to see what they say....
