19mm rear sway
Old 05-12-2008 | 11:50 AM
dale55's Avatar
Default 19mm rear sway
Where to buy?
thanks,
dale
Old 05-12-2008 | 11:59 AM
beachchair's Avatar
Default RE: 19mm rear sway
Check this out. Good price.
http://supremepowerparts.com/applica..._Sway_Bar_19mm
Old 05-12-2008 | 12:18 PM
scoTT la rock's Avatar
couple of bucks cheaper than the beachchair link, but the difference is negligable:
http://www.mjmautohaus.com/catalog/p...roducts_id=283
Old 05-12-2008 | 04:25 PM
MeanAudiA6's Avatar
great mod i got mine from mjm
Old 05-12-2008 | 09:37 PM
ORIGINAL: MeanAudiA6
definitely. my car feels like i can make a hard left turn at 70 and im still glued to the ground.
i just picked up the 22mm neuspeed front sway- as soon as it FINALLY arrives im gonna throw that b*tch on. finally- good bye creaking stock swaybar!! my car will no longer sound like im in the belly of the black pearl...
Old 05-12-2008 | 10:06 PM
achTTung's Avatar
I think the sleeves have fallen out of the bushings on my front bar. It doesn't creak anymore, it clunks, but whatever, its low on the priority list.
Old 05-12-2008 | 10:24 PM
theTTkid's Avatar
so whats high on the priority list?
Old 05-12-2008 | 11:34 PM
randomloginname's Avatar
just make sure you put the dogbone back together right...I here if you put it back together wrong it still fits but rubs the fsb not sure if you have to pull that mount or not, but its right there anyways if you havent upgraded the bushing
Old 05-13-2008 | 12:07 AM
achTTung's Avatar
ORIGINAL: theTTkid
How 'bout non functioning haldex, large EVAP leak, and only boosting to 10psi on a 225 w/o any codes.
Old 05-13-2008 | 06:20 AM
beachchair's Avatar
ORIGINAL: randomloginname
It is possible to put the dogs in the wrong way. I did, before I double checked prior to letting the car down off the jacks.
Quick Reply: 19mm rear sway
