02 sensor / fuel filter / upgraded plugs! I need your help!
I need to replace my O2 censor in bank 1.
Where is it located? - What is the best way to remove and insert the new one?
Fuel filter - Where is it?
Where is it located and what is the best way to remove the old and insert the new?
Plugs, Its pretty self explaing. - Does this car have anything special I should be watchful of?
I'm also adding a KandN air filter into my current box. - Anything I should watch out for?
Thanks guys!!!!!!!!
Thanks guys!!!!!!!!
RE: 02 sensor / fuel filter / upgraded plugs! I need your help!
ORIGINAL: bmwtoaudi
Where is it located? - What is the best way to remove and insert the new one? - in the dp about 1' below the turbo. you should be able to remove it with the dp still attached. make sure you use plenty of pb blaster/wd40 and a o2 socket to get it out.
Spark Plugs
[ul]OE Plugs: NGK PFR6Q - .032" gap
For Stock Cars - .032" gap:
[*]NGK BKR6E
[*]Autolite 3923
[*]Denso Iridium IK20
For Chiped Cars - .028" gap:
[*]NGK BKR7E
[*]Autolite 3922
[*]Denso Iridium IK22
[/ul]
I'm also adding a KandN air filter into my current box. - Anything I should watch out for? - should be nothing but when you clean it, dont over oil it.
Thanks guys!!!!!!!!
Spark Plugs
[*]NGK BKR6E
[*]Autolite 3923
[*]NGK BKR7E
[*]Autolite 3922
[/ul]
Thanks guys!!!!!!!!
fuel filter is an easy DIY....its located on the rear passanger side near the fuel tank....you will have to remove the plastic protector cover to gain access.....then you will easily see it there. just follow the fuel lines...also to undo the connectors you have to push the tabs in and pull out. called "push tabs"
skihigh2299
10-11-2015 05:54 PM
Nevalite
03-30-2010 12:13 PM
joeq10
07-24-2007 07:51 AM
MC Hammered
09-09-2006 05:18 PM
