00 audi tt a/c compressor removal
Does anyone have a how to on the a/c compressor removal? It looks almost impossible to remove with the power steering pump on the bottomw still on. If anyone has pics on how to then that would be great.
My engine was out of the car when it was changed. But you most likely need to remove the alternator before you can remove the compressor. The alt takes no more than an hour to swap so it wont add to much time added time. Just make sure you have to correct connector before you start the swap, if they are different, you need to swap the connector so they match.
Finally I found this thread about the Alternator.. Just need one for the A/C. Lol.. http://www.audiworld.com/tech/eng92.shtml
