00 audi tt bov question...
After reving it to peak and then the bov goes off and completly let it come back down to idle the car dies insteads of idles... it is only when it is at high rpms it does this. Does it need to be adjusted or do I need a addition part for the bov. It is a blitz bov and it came with tube, plug for the DV and the T vacuum hose connector. Any suggestions. Thanks
RE: 00 audi tt bov question...
you should see if you are pulling any codes regardless of cel to see if you are running rich. your engine is expecting that air youare venting to atmosphere. theres no benefit to runnning a bov on this engine except to hear the noise. please check the faq for more info
ORIGINAL: randomloginname
ORIGINAL: audi_tt_4u
Why even reply then?[sm=icon_beat.gif]
run the blitz to a recirculating BOV if its capable....usually some adapter you have to buy to make it capable....these cars dont like BOVs as much as DV(diverter valves) most questions can be answered if you read the TT FAQ at the top of the TT forum
ORIGINAL: cincyTT
cause i know 100% the reason why its doing what its doing and i know you wont be greatful for the response due to previous experience
run on sentence anyone? Ok, ill give you this little tip, you wont ever get that bov to work on your car.
Oh, and dont flatter yourself becuase i read threads and you just happen to of posted.
