TV Tuner
I don't think there is a fuse inside the tuner module.
Check all the connections (fibre, FBAS, FAKRA, etc) and if you have VCDS (VAG-COM) or know someone who does a scan will help.
Not sure which country you are in, but I've seen a few of them on ebay.de and of course kufatec.de has them.
There's a company in the UK who parts out A8's on ebay that might be worth a look.
In the US you might try audiusaparts.com or worldimpex.com - anywhere else is going to be less than the dealer.
Thanks for your reply . I did check the connections and they are fine the vcd cannot detect the tv tuner . The tuner seems to be quite difficult to remove as it's on the inside of the rack and a lot of wires around it . Do i need to remove everything in order to unbolt the tuner
I've checked the connections on the tuner and they are fine .I've forgotten to mention that not just the TVicon is missing on the MMI but also the AV1 &AV2. Could it be an interface that is playing up and where is it located if there is one
Thanks
Thanks
