Stiff steering one direction
I have been having a problem with my steering in my 2001 A8 4.2 after visual inspection of the components (rack) boot ect i dont see any leaks although i have only had the car a year the steering has gone from getting stiff from time to time To being totally hard to steer right turning left doesn't feel bad . Any suggestions would be helpful before i take it to the stealership I have clean the filter in the pump but that didnt help. My next task is to flush the system
whata you think
Greg
whata you think
Greg
Double check the control arms and make sure anything isn't blocking it. If everything looks ok you need a new rack, chances are the valve inside the rack is stuck and only allowing the fluid to go to one side of the rack.
