ineed maximum offset, tire size for 01 s8
Old 12-09-2006 | 07:14 PM
gtos8bthgoxxx's Avatar
Default ineed maximum offset, tire size for 01 s8
he stock offset and how wide within the wheel wells would be nice. isee these rims on ebay under s8 that are 8.5 x 18 with a 35mm offset but 8 x18's that are 42mm.
Old 12-09-2006 | 10:19 PM
AWDaholic's Avatar
Senior Administrator
Default RE: ineed maximum offset, tire size for 01 s8
42 is teh stoclk offset. My aftermarket wheels (notice I calle dthem *wheels,* not rims) are a 35mm offset, and I have no clerance problems with my stock calipers, which is promairly what you're worried about, with a smaller offset. With too much, or too little, not only should you be concerned with clearance (caliper, or fender, depending...), but your wheel-bearings'll take a bit more abuse than they were designed for.
Old 12-09-2006 | 10:54 PM
42mm offset moves the tires closer to the strut or inner wheel well. the smaller the number offset the further out the edge of the tire sits. the calipers clear as long as the diameter of the wheel is first ok. i bet 14 inch rims would never fit. i know 255's would fit both 8 and 8.5 rims but im really worried about the 12 mm pull to the fender flares. maybe someone out there remembers the offsets on there successfull wheel tire combo's.
Old 12-09-2006 | 10:58 PM
correction 7 mm pull outward
Old 12-10-2006 | 04:09 AM
AWDaholic's Avatar
OK, in that case, with my 35mm offset, not only do my calipers clear just fine, I have no fender clearance issues, either, at stock ride height (for a '99 D2, that is). Actual clearance may vary, depending on how you drive, where you drive, and how much you've lowered your car...
fidelite
06-24-2008 03:06 PM
trill
01-01-2008 08:33 PM
blks4
11-28-2007 05:48 AM
zebinheimer
12-05-2006 12:36 AM
zebinheimer
12-03-2006 10:30 PM
Quick Reply: ineed maximum offset, tire size for 01 s8
