Implausible Value
Old 12-10-2006 | 07:18 PM
rupz's Avatar
Default Implausible Value
Hello, Hope someone can help!
This error code has started to appear on my UK spec 2001 3.7 A8:
17549/P1141/004417 - Load Calculation Cross Check: Implausible Value.
I understand most probable causes are Mass Airflow meter (G70) or Intake manifold pressure sender (G71). After changing the Mass Airflow meter the code is still there.
1/ What Engine Measurement blocks do I need to look at with my VAG.COM software to see the Intake manifold pressure sender?
2/ Where is the Intake manifold pressure sender (G71) located? (Hope it’s not inside ECU)
Thanks in advance for any assistance,
Rgds, Rupz
Old 12-16-2006 | 02:05 PM
dankhound's Avatar
Default RE: Implausible Value
Are you sure your vehicle has one? Itd be uncommon for a vehicle to have both a maf and a manifold pressure sensor. Check your throttle position sensor to make sure its reading correctly.
Old 12-16-2006 | 08:51 PM
rupz's Avatar
Thanks for advise, I’ve just carried out the throttle valve adaptation and fault code has gone for now. Reading the workshop manual I should have done this after the main battery had low volts. Cheers.
Napier.Nomad
Audi Q7
07-08-2014 12:14 AM
eazy211187
02-01-2013 04:42 PM
pete7
10-13-2009 08:55 AM
BoulderAudi
12-25-2007 05:30 PM
