Coolant and Engine oil mixed problem 2007 A8
I have 2007 A8 with 100,000 miles and I have the problem, coolant and engine oil mixed.
I realized coolant level decreased after I filled it up and I was shocked because engine oil looked like jam when I changed an engine oil and filter.
The coolant is decreased because coolant and engine oil mixed.
Is this a common issue for Audi?
Anyone had same issue and have a solution?
Please help me.
Please help me.
Start with a compression test first... if all numbers do not match then most likely you have blown head gasket. Either way those fluids mixing it means serious engine problem... and no its not common for Audi or any other car manufacturer to mix coolant and oil.
Did the oil looked like chocolate milk?
The oil looked like chocolate color and very thick.
