Battery draining problem
Hi,
I was wondering if you could help me resolve it ?! here is the problem:
I bought the car around 30 days ago - Audi A8 D3 4E, 2004 4.2 Petrol ( before buying it I had it checked in a dealers shop – one of the fault codes that the dealer pointed out to me was that the front left door has a fault code that means the car does NOT know when the door is opened or closed) they did also say that the only thing that this could bite me on the a** was that I could accidentally lock the key inside if not on the ignition when the car autolocks. About ten days ago I noticed that when I enter in my car in the morning the bat. Manager from the MMI shows 10% (no more, no less – every morning) When I unlock in the morning the lights in the boot do not light and MMI is in German. I set it to English, I drive approx. 30-40 min and the battery manager says that it is 100% charged. I lock, after an hour or so I unlock (the lighs in the boot light, the MMI menu is in English and all else is good. I lock in the evening and in the morning…the same… 10% battery, no boot and trunk light, german menu.
Battery is original from dealer installed and coded week 25 year 2013 (had it tested in two battery shops) - OK
Alternator also tested – OK
Car starts with the key – no button, no finger print reader on central console or outside door handles
Please help me to determine if this issue with the front left door is the reason for the Battery drain!!!
I can Also post VCDS codes from autoscan if needed
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 19 1E 25 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 65 72 76 77
VIN: WAUZZZ4E64N011825 Mileage: 189350km/117656miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0008597
Shop #: WSC 00120 000 00000
VCID: 21456687A8C9EA0B2CD-8074
1 Fault Found:
00003 - Control Module
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0C9124967
Coding: 0262144
Shop #: WSC 02311 785 00200
VCID: D8B38B633B13EBC39B3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00166 - Access/Start Authorization Switch (E415)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 0
Reset counter: 101
Mileage: 188992 km
Time Indication: 0
Date: 2014.02.21
Time: 11:13:48
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:22
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 F HW: 4E0 035 729 A
Component: Interfacebox H43 0350
Revision: 00000000 Serial number: 300IH037526037
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 2B5984AFDA05305B861-807E
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 301JM037527174
Subsystem 3 - Serial number: 7410.10.030000000000010037ÿ
Subsystem 4 - Serial number: 010037ÿ
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 32
Mileage: 186651 km
Time Indication: 0
Date: 2014.01.24
Time: 07:46:32
01042 - Control Module; Not Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 189268 km
Time Indication: 0
Date: 2014.02.27
Time: 10:27:03
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0011006
VCID: 2A5781ABD5FF29537D7-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 188751 km
Time Indication: 0
Date: 2014.02.15
Time: 20:25:38
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 D HW: 4E0 907 561 D
Component: ABSTANDSREGELUNG 0010
Coding: 0011168
Shop #: WSC 02313 785 00200
VCID: 23496C8FB2D5F81B3E1-8076
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 5
Reset counter: 98
Mileage: 188740 km
Time Indication: 0
Date: 2014.02.15
Time: 17:47:00
Freeze Frame:
Temperature: 21.0°C
Voltage: 11.65 V
Bin. Bits: 00000010
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H12 0040
Coding: 0012151
VCID: E5CDB2977C61462B105-80B0
Component: Lenkradmodul H02 0050
No fault code found.
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 930 HW: 4E0 920 930 E
Component: KOMBIINSTR. VDO H51 0080
Revision: D12 Serial number: AUDID3C9000671
Coding: 0000103
Shop #: WSC 00130 470 95695
VCID: DFC1A07F5E3D1CFBDA9-808A
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0070
Revision: 07 Serial number: 130040390903D9
Coding: FEFE7BDD2B3504
Shop #: WSC 00000 128 00289
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 HW: 4E0 035 111
Component: CD-Changer H43 0220
Revision: 00000501 Serial number: AUZ5ZBC1024325
VCID: D6AF855B3107DDB389F-8083
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 16
Reset counter: 67
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.25
Time: 19:14:07
Freeze Frame:
Text: 00005719
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0262144
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 101
Mileage: 188992 km
Time Indication: 0
Date: 2014.02.21
Time: 11:13:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:22
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
VCID: 264F759BC1E70D3359F-8073
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 188751 km
Time Indication: 0
Date: 2014.02.16
Time: 13:16:39
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory FS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063330
2 Faults Found:
01970 - Seat Depth Adjustment Button (E350); Backwards
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 9
Reset counter: 70
Mileage: 189252 km
Time Indication: 0
Date: 2014.02.25
Time: 01:22:45
01969 - Seat Depth Adjustment Button (E350); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 70
Mileage: 189252 km
Time Indication: 0
Date: 2014.02.25
Time: 01:22:45
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H42 1060
Revision: 00000000 Serial number: 305IQ037546480
VCID: 3B79B4EF2A65A0DB161-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000324100071
VCID: 1D3D5A7794B1CEEB085-8048
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028449
VCID: DEBF9D7B593715F3D1F-808B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040310070025
Coding: 0000584
VCID: 2751789FC6ED143B629-8072
3 Faults Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 3
Mileage: 155053 km
Time Indication: 0
Date: 2011.08.07
Time: 20:55:24
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 109
Mileage: 189214 km
Time Indication: 0
Date: 2014.02.24
Time: 00:07:01
004 - No Signal/Communication
Freeze Frame:
Fault Priority: 3
Reset counter: 3
Mileage: 155053 km
Time Indication: 0
Date: 2011.08.07
Time: 20:55:24
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 E HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0210
Revision: PROD_01 Serial number: 00000000459715
Coding: 0000016
VCID: 1F41607F9EBDDCFB1A9-804A
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000023573
Coding: 0010111
VCID: DDBD9A7754310EEBC85-8088
Subsystem 1 - Part No: 4E0 910 511
Component: UGDO HL ECE H04 0030
Subsystem 2 - Serial number: VK4975T08Y9E
1 Fault Found:
02072 - Control Module for Energy Management (J644)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028449
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Shop #: WSC 00011 888 96745
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 B HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0220
Revision: 00000000 Serial number: 304JX037548665
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 A HW: 4E0 919 146
Component: TV analog TUNER H12 0180
Revision: 00000009 Serial number: 00000000002699
Coding: 0001002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000004653075
VCID: 1E3F5D7B99B7D5F311F-804B
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 330619J09L
Coding: 303030393135313035414B5641303333303631394A30394C
5 Faults Found:
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 255
Mileage: 189214 km
Time Indication: 0
Date: 2014.02.24
Time: 00:14:32
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 17
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:00:48
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:01:08
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:01:18
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 110
Mileage: 189254 km
Time Indication: 0
Date: 2014.02.26
Time: 04:20:33
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028449
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
Shop #: WSC 09725 111 00808
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 195
Reset counter: 70
Mileage: 188674 km
Time Indication: 0
Date: 2014.02.14
Time: 09:37:29
Freeze Frame:
Speed: 0.0 km/h
Temperature: 5.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 188696 km
Time Indication: 0
Date: 2014.02.14
Time: 15:10:03
Freeze Frame:
Speed: 14.0 km/h
Temperature: 15.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028449
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001008
VCID: E0C3A38363432303E33-80B5
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 C HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0210
Revision: 00000004 Serial number: T2AUD308090CP8
Coding: 0000004
1 Fault Found:
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 107
Mileage: 189249 km
Time Indication: 0
Date: 2014.02.25
Time: 19:14:50
End ---------------------------------------------------------------------
Coding: 0008597
1 Fault Found:
014 - Defective
Coding: 0262144
Component: ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 101
Mileage: 188992 km
Time Indication: 0
Date: 2014.02.21
Time: 11:13:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:22
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 32
Mileage: 186651 km
Time Indication: 0
Date: 2014.01.24
Time: 07:46:32
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 68
Mileage: 189268 km
Time Indication: 0
Date: 2014.02.27
Time: 10:27:03
Coding: 0011006
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 104
Mileage: 188751 km
Time Indication: 0
Date: 2014.02.15
Time: 20:25:38
Coding: 0011168
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 5
Reset counter: 98
Mileage: 188740 km
Time Indication: 0
Date: 2014.02.15
Time: 17:47:00
Freeze Frame:
Temperature: 21.0°C
Voltage: 11.65 V
Bin. Bits: 00000010
Coding: 0012151
Coding: 0000103
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 67
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.25
Time: 19:14:07
Freeze Frame:
Text: 00005719
Coding: 0262144
Component: ELV XXXX
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 101
Mileage: 188992 km
Time Indication: 0
Date: 2014.02.21
Time: 11:13:48
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 189248 km
Time Indication: 0
Date: 2014.02.26
Time: 14:23:22
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 102
Mileage: 188751 km
Time Indication: 0
Date: 2014.02.16
Time: 13:16:39
Coding: 4063330
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 70
Mileage: 189252 km
Time Indication: 0
Date: 2014.02.25
Time: 01:22:45
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 70
Mileage: 189252 km
Time Indication: 0
Date: 2014.02.25
Time: 01:22:45
No Faults Found
Coding: 0028449
Coding: 0000584
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 3
Mileage: 155053 km
Time Indication: 0
Date: 2011.08.07
Time: 20:55:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 109
Mileage: 189214 km
Time Indication: 0
Date: 2014.02.24
Time: 00:07:01
Freeze Frame:
Fault Priority: 3
Reset counter: 3
Mileage: 155053 km
Time Indication: 0
Date: 2011.08.07
Time: 20:55:24
Coding: 0000016
Coding: 0010111
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 107
Mileage: 0 km
Time Indication: 0
Date: 2023.06.06
Time: 00:00:00
Coding: 0028449
Revision: AV1C1010
Coding: 0000531
Coding: 0000001
Coding: 0001002
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 255
Mileage: 189214 km
Time Indication: 0
Date: 2014.02.24
Time: 00:14:32
Freeze Frame:
Fault Priority: 7
Fault Frequency: 17
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:00:48
Freeze Frame:
Fault Priority: 7
Fault Frequency: 14
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:01:08
Freeze Frame:
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Mileage: 189215 km
Time Indication: 0
Date: 2014.02.24
Time: 02:01:18
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 110
Mileage: 189254 km
Time Indication: 0
Date: 2014.02.26
Time: 04:20:33
Coding: 0028449
Coding: 0212127
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Reset counter: 70
Mileage: 188674 km
Time Indication: 0
Date: 2014.02.14
Time: 09:37:29
Freeze Frame:
Speed: 0.0 km/h
Temperature: 5.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 57
Mileage: 188696 km
Time Indication: 0
Date: 2014.02.14
Time: 15:10:03
Freeze Frame:
Speed: 14.0 km/h
Temperature: 15.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028449
Coding: 0001008
Coding: 0000004
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 107
Mileage: 189249 km
Time Indication: 0
Date: 2014.02.25
Time: 19:14:50
RickA6
04-11-2011 11:21 PM
