4.2 A8 cam position sensor code
Old 07-02-2005 | 08:45 PM
Dave Ray's Avatar
Default 4.2 A8 cam position sensor code
I have recently bought a 1998 A8 4.2 Quattro. I have a check engine light with a code 1392, and 0432. The 1392 says the cam position sensor needs to be checked and the 0432 says the main Cat. bank 2 efficiancy below threshold. I've checked the cam position sensor and found it has a good ground, the correct power supply, and is sending out a signal. I've checked the wiring between the sensor and the ECM and it all checks good. This sensor seems pretty simple, could it be failing intermittently??? Has anyone ever seen this problem[/size]?
northbayrayray
03-19-2015 12:32 PM
brico
02-04-2014 11:49 PM
Peterhopson84
08-20-2013 10:57 PM
craig825
06-03-2013 07:55 PM
Freq
06-06-2011 05:09 PM
