2005 A8 Power Trunk
How to replace the trunk lid struts?
Technical Service Bulletin 55-06-01, Concern #2 addresses your description directly.
"...may be caused by:
Trunk lid hinge is stiff (corrosion in the hinge joints).
Wrong Gas-filled strut installed.
Trunk lid drive unit does not provide enough torque for operating the trunk (particularly in subzero temperatures), solenoid clutch in the drive slips through."
The fix involves replacing the hinges and/or motor. Bummer...
I was wondering if any body knows how to replace those gas filled struts that assist lifting the trunk lid. I bought a pair online and wanted to try to do it myself. By just looking at them, it seems to be a little complicated.
Thank you so much,
A.
Audi A8 Boot problem
I have the same problem as the DaveG73.
The boot lid tries to lift and shuts again. To open it I have to help it up about 30mmand it opens automatically and when I press the button it closes without any problems.
Can you please help? I am handy mechanically.
Regards
Regards
trunk won't go uo
The power trunk does not lift automatically using either the key fob, button on the trunk, or the drivers door. Dealer told me the lift motor is bad. $828.00 to replace it.
Does anyone know where I could get a replacement motor? And the instructions to replace it myself?
Thanks!
Thanks!
You can raise the grommet screw up on the drivers side of the trunk and it will work on its own. If you can't raise it enough put a spacer on top.
Not only is the adjustment working flawlessly the trunk springs open like it used to. I don't believe in a bigger hammer mentality I like to get to the root of the problem before I start changing things. Simply physics wins every time .
Yep, that's why Audi designed a more powerful motor
If it works the cheap way go for it - no need to spend additional money if the fix gets you by for a while !
#18
Excellent. You know where to find the part # if/when it fails.
I've seen a lot of these... hopefully yours is the exception.
I was pleased to see the D4 engineers scrapped and corrected the whole ridiculousness of that design.
#19
Try this repair before buying a replacement motor:
Remove the trunk motor.
Open the motor casing. (Several torx screws to remove)
Use rosin (the material used to coat violin bow to increase friction) to rub round the magnetic side of the coupling. The idea is to increase the friction to prevent slipping when opening the trunk.
Revers the process.
It worked in my case, in which the trunk would open an inch or so before dropping back down. Probably 20-25 minutes needed in total.
Revers the process.
#20
I have this problem on a 2006 a8l. I have to help the bonnet up about .5 inches before the motor takes over and continues to lift it. It closes and locks fine.
Can you help me with the gromet screw you ar speaking of?
