A7 Start/Stop Disable
I have done my car so it remembers if I left it off or on and not just default to the on position after the car has been turned off.
It can also be turned off perm if you want to too but pointless as just doing what I have done you can leave it off.
Try this on VCDS...
Disable/memorize/invert Start & Stop:
- module 09-Cent. Elec.
- enter Security Code (20113)
- Adaptation on Channel 34:
subtract 4 to the value --> Start & Stop always disabled
add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
- test & save
In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled.
Try this on VCDS...
- test & save
