Xenon headlight problem.
Old 01-08-2008 | 11:00 PM
tdied's Avatar
Default Xenon headlight problem.
I have a 2003 Allroad 2.7 with xenon headlights. I recently had the front bumper and headlights off of the car. I was still starting and moving the car around without the headlights in the car. AfterIinstalled the lights and start the car I get a service light on the dash. The manual says it is a problem with the auto leveling system in the headlights. How can I clear this service code? I have access to a vag-com. Any ideas on this?
Old 01-13-2008 | 02:29 PM
dankhound's Avatar
Default RE: Xenon headlight problem.
Most likly you just have faults for open circuits in the headlamps due to starting the car with the lamps unplugged. Just erase the faults. Its module 55 for headlamp range control on the vag com.
Old 01-13-2008 | 10:49 PM
tdied's Avatar
When I connect the vag-com to the car it says no communication with the headlight level control module. I have taken everything apart again and all connections look good. The owners manual says that there should be a fuse in the #10 position in the main fuse panel. My car does not have a fuse there or pins to accept a fuse. Could there be another fuse someplace else I am missing?
essigwagen
01-31-2016 03:03 AM
nick@ion-e.com
02-25-2015 04:15 AM
oldmots
04-24-2012 06:53 PM
deadeyeknight
07-06-2011 06:23 AM
StevenTownsend
11-28-2005 02:56 PM
