wheres the stock amp
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
ok listen ... easy if your speakers say bose then you have a bose system if they dont then you have a regualr facotry system
truth be told the bose speakers sound liek crap if you take away teh bose stock headunit ... teh amp is located on the passenger side in front of the sub yet behind the back seat on teh passenger side in the truck ... u ripped the lining off the wrong side lol if you dont have a bose then simply wire the amp and subs right to the factory head unit or if you bought a new head unit (which is a good idea for subs neway) ... if you have the bose you cant put your subs and amp into the headunit you need to tap power and sound in the truck BUT BEFORE the amp not after the amp
it is not as hard as everyone makes it seem although i just did trial and error my first time!
let me knwo if you have any problems ill try to walk you through it but you seem like you know what your doing ...
o yea and be sure to run RCAs and your amp power from battery down diff sides of teh car if you do have the bose bc you will experience a small amount of feedback when your A/C is on and you accelerate
Yes that is the sub and amp,the amp is inside right near the sub, which is just a small amplifier that powers both the rear speakers and the subwoofer. You can't really do much with the factory amp so if you wish to upgrade you will need to get another amplifer to power the subwoofer.
Well I just took mine apart and took a peek inside to see where everything is, then added some insulation...now everything just rattles even more. And he did ask "Is this the sub or amp?" So I just wanted to clarify things up a bit.
Thanks joe and Asianicestyles for clearing that up.
What if I got a rns-e ? It shouldn't be any different right? And after market speakers would sound way better than the factory right?
here u got ... http://www.metacafe.com/watch/444044..._installation/ i love the music in the background LOL
yea if you are eliminating the bose head unit with bose speakers then get new speakers all around some nice 3 ways
if you have the plain old symphony the speakers shoudl be replaced anyways
#18
yea I'll change my speakers than, what size can I fit in they?
And what I ment to say when hooking up a amp to a rnse it should be the same as hooking it to the head unit? Cause I'm thinking bout getting one
