What is the biggest rim size you can put on ?
RE: What is the biggest rim size you can put on ?
I guess your right, its not like its front or rear wheel drive, Ive seen rwd car withdifferent size rims,I was just woundering.I think Im gonna do the 19's, big rims always look better....I think away.
ORIGINAL: blacka6
20s wont fit and 18s look cheap and small. if you have the money i imagine a custom shop could make 20s fit but it might not be worth the money. i stuffed 19s under my 95 a6 quattro and it sits sort of high, not much higher than my ugly 17s it cam with but do need to lower it to make it look good. hope this helps, hope my pics make it in the post. d-
[IMG]local://upfiles/8632/DC06C551165241E78C574FCD83D008A9.gif[/IMG]
i have 19x9.5 and it looks great. here are some picture i also have the wheels for sale.
as you can see it fills the gap perfect without any rubbing. i have 265/30/19 the same diameter as the stock wheels so nothing is affected it seems to take corners extremely nice and i also have 10mm spacers in the front to clear the huge *** calipers.
sure do looks good on sports suspension. u willhave to roll your fender 1/2in with sports suspension but if yor non sport then its fine. if you dont roll your wheels will rub on the outside fender of the wheel well but that only under a hard bounce...like going 90mph over a speed bump that is 5in high. it rubs on occasion when i hit a hole in the street. but beside that the car is awsome on these wheels the stance is like no other.
