warm up catalyst code
It may be a sign of CAT converters going bad, or Post CAT O2 sensors going bad. Try to replace Post CAT O2 sensors first. It worked on my car. You can also try a trick with a diode to save money on new sensors. The trick works fine. I tested it. Unless there's something else going on with sensors, you should not see these codes anymore.
