valve cover gaskets question
RE: valve cover gaskets question
ORIGINAL: modset
are you sure you have to remove the timing belt? no where does it mention that in the bentleys or on any write ups i've found.
I just did this job over New Years weekend. Trust me, the TB has to be off.
YOU DO NOT HAVE TO REMOVE THE TIMING BELT TO REMOVE THE CAM CHAIN TENSIONER GASKETS. You remove the Valve Covers then use a 3366 tool tocompress the cam chain tensioner and release the gaskets. Slip the new gaskets in place and retighten the tensioner. Then replace the valve cover gaskets.
Here's a link to the whole procedure: http://forums.audiworld.com/a6/msgs/517769.phtml
True, I have done this on a slightly older A6 2.8l there are just two little posts that are coming up from ether side that makes it a PITA. just takes a bit of wiggling. we have a tool that is a screw with a piece of plastic on it that compresses the cam chain I belive. But I dont think it is possible without the tool. so you may be takin the belts off.
ORIGINAL: madridlover
YOU DO NOT HAVE TO REMOVE THE TIMING BELT TO REMOVE THE CAM CHAIN TENSIONER GASKETS. You remove the Valve Covers then use a 3366 tool to compress the cam chain tensioner and release the gaskets. Slip the new gaskets in place and retighten the tensioner. Then replace the valve cover gaskets.
I stand corrected...I thought you meant the cam chain tensioner gaskets.
