Valve cover Gaskets 2.8 30v 98
Old 05-19-2008 | 05:14 PM
JcoyA6's Avatar
Default Valve cover Gaskets 2.8 30v 98
Can any direct me to the write up on how to change just the valve cover gaskets?
Old 05-20-2008 | 12:53 AM
SquirrelA6's Avatar
Default RE: Valve cover Gaskets 2.8 30v 98
I just did mine this past weekend for the first time. I found helpful info on AudiWorld/Tech Section. Also do a search on this forum and you will find a few. The biggest snag I had was getting the spark plug wires out. Their a PITA on the 2.8. Also, getting the Valve Cover loose was tricky, you have to bang it with a soft mallet and pull up on the little tabs on the top and bottom. It took me a while, and then it popped loose and came off easy.
mradams316
10-17-2011 02:33 PM
fowvaydriver
08-01-2011 10:46 PM
cwedholm1
11-03-2009 09:03 AM
A6 Quattro V6 30V
09-19-2007 11:57 PM
dubd012
01-12-2007 03:53 PM
Quick Reply: Valve cover Gaskets 2.8 30v 98
