Vag Com readout. Need help with CEL
VCDS-Lite Version: Release 1.0
Friday, 05 November 2010, 16:21:10:0
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,65,67,75,76,77
Address 01: Engine Labels: 078-907-551-AZA.LBL
Controller: 4B0 907 551 K
Component: 2.7l V6/5VT G 0005
Coding: 06612
Shop #: WSC 40205
5 Faults Found:
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28): Incor. Correl.
P1347 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16691 - Cylinder 7: Misfire Detected
P0307 - 35-00 - -
16696 - Cylinder 12: Misfire Detected
P0312 - 35-00 - -
16698 - Misfire(s) Detected; Single (unspecified) Cylinder
P0314 - 35-00 - -
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.LBL
Controller: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
Address 15: Airbags Labels: 4B0-959-655-AI7.LBL
Controller: 4B0 959 655 F
Component: Airbag Front+Kopf 1002
Coding: 00406
Shop #: WSC 02325
Address 16: Steering wheel Labels: 4B0-907-487.LBL
Controller: 4B0 907 487
Component: E Lenkrad Elektronik D03
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Controller: 4B0 920 980 M
Component: C5-KOMBIINSTR. VDO D10
Coding: 02264
Shop #: WSC 00000
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Controller: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15981
Shop #: WSC 30011
11 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01575 - Control Switched Off
35-00 - -
01380 - Alarm triggered by Anti-Theft Sensor; Rear Left
35-00 - -
01379 - Interior Monitor Switch (E183)
35-00 - -
35-00 - -
00970 - Unknown Error Code
09-10 - Adaptation Limit Surpassed - Intermittent
00974 - Switch for Heated Windshield (E180)
01595 - Tire Pressure Control Switch (E226)
35-00 - -
01597 - Drive Battery Pre-Charge Circuit
35-00 - -
01613 - Relay for Fuel-Cooling Pump (J445)
29-00 - Short to Ground
01615 - Tank Door Remote Unlocking Switch (E204)
Address 36: Seat Mem. Drvr Labels: None
Controller: 4B0 959 760 A
Component: Sitzmemory D05
Address 45: Inter. Monitor Labels: None
Controller: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00101
Shop #: WSC 02325
2 Faults Found:
01349 - Alarm via Theft Warning System; Front
35-00 - -
01353 - Wire for Clock/Pulse Signal; Rear at 5V
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D003
Coding: 00006
Shop #: WSC 02325
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Controller: 4B0 035 195 A
Component: Radio D00
Coding: 00117
Shop #: WSC 02325
End --------------------------------------------------------------------------------------------------
Coding: 06612
Shop #: WSC 40205
5 Faults Found:
P1347 - 35-00 - -
P0303 - 35-00 - -
P0307 - 35-00 - -
P0312 - 35-00 - -
P0314 - 35-00 - -
Coding: 0273004284
Shop #: BB 24334
Coding: 00160
Shop #: WSC 02325
Coding: 00406
Shop #: WSC 02325
Coding: 02264
Shop #: WSC 00000
Coding: 15981
Shop #: WSC 30011
11 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Coding: 00101
Shop #: WSC 02325
2 Faults Found:
35-00 - -
35-00 - -
Coding: 00006
Shop #: WSC 02325
Coding: 00117
Shop #: WSC 02325
