The ultimate thread about catalytic converters replacement
Hello everybody,
I'd like to wrap-up the cats replacement threads for all those like me that are getting trouble codes and cannot have the ECU re-flashed.
From all those that replaced their A6's cats, I'd like to hear your stories, with a final word. In fact, most of older threads do not have a "the end", so they leave others without a clear picture of what's best to do.
Do you suggest genuine, aftermarket or universal (non direct fit) cats?
How much did you spend?
Most importantly, did you solve the CEL problem for good?
Thanks
Thanks
Why did you even answer his thread if you wasn't going to answer the thread! You just added useless space to the thread, making it longer then it has to be!
Now, for his question. What kind of Cats are you using? I was looking at racing cats for my car, I was wondering if you had racing Cats on your car, maybe thats why its giving you codes. I don't want codes, thats why I'm asking.
In fact, I am proposing to all of them who went through the PITA of replacing cats on their A6 to share their experience so others will benefit.
That way, this will become the ultimate thread about the cat replacement on A6s. Do you grasp the concept?
If you have nothing to say about it, just disregard this thread. Thanks.
Of course in California you can't buy aftermarket cats (at least most of them). But other than that, the point is how you guys have solved your cat problem?
Nobody who wants to share?
The cats are good and just the Audi ECU specs too narrow for check engine light on, check out www.bigdaddiesgarage.com
The O2 sensor minicat could work, but I'm afraid that there's a lot of work to remove the O2 and install the O2 w/minicat...
