tryin to figure out what size tires should go on my 18's
![Default](https://www.audiforums.com/forum/images/icons/icon1.gif)
I am running 235/40-R18 with Conti's and there is no problem. The speedo was always a little off and this does not make it significantly worse. I'm probably going to go with 245/40-R18s when these have to be replaced to get a little wider tire, more rim protection, and to fill the wheel wells more.
Does anyone out there know if the A6 4.2 axle is wider or is it just the body style?
I ran this through the Discount Tire calculator for 235/40-R18 vs 245/40-R18 and the 245 is .4" wider, .32" taller (and this is only .16" as half is below and half above the axle), and reads 65 at 65.81 actual. I doubt the height is an issue. The width may be an issue because of the offset, but even there I appear to have at least an inch between the tire and any suspension part. And the suspension parts in question move with the wheel. Is anyone out there running 245/40-R18 tires?
#18
I am running Conti 235/40-ZR18 on RS4 replica rims with no clearance issues at all. Here are the specs on the rims, if that helps:
Diameter - 18";
Width - 8.5";
Offset - ET38
I'm trying to find out if 245/40-ZR18 will fit the car as the Contis will have to be replaced after this summer. This tire is .32" taller and .4" wider.
Diameter - 18";
Width - 8.5";
Offset - ET38
fumoazul99
02-02-2010 09:17 AM
