trunk release button in door frame
Hi All- New '03 2.7T owner in the DC area. My trunk lid switch was missing the button part (the plastic piece that you press), so I ordered a new one from worldimpex and now have the part. However, I'm not quite sure how to replace it. I could probably pop out the plastic piece from the new one and replace it on the old one, but I think it might be better to replace the whole switch if I can figure out how to get it out. Advice?
RE: trunk release button in door frame
What happened to me was that the button broke and came out, leaving a hole as you described.
I ordered a new switch (around 25$ CAD) and just replaced it myself.
The switch comes whole and you just toss out the old one. I pried the old frame and everything out gently with a screwdriver, removed the wire from the old switch, put it onto the new switch and then just popped the new assembly into the slot pushing with firm pressure.
Basic instructions (from memory, so forgive me if I forgot about a screw or a bolt here and there):
1.Tools:
-flat head screwdriver (medium)
- small socket wrench (1/4")
- 11mm (i think) long socket
-needlenose pliers
2. Open both driver side doors. Use flat head screwdriver and hands to gentlyremovethe plastic floor trim by both doors.
- there are several clips on the bottom side that slide into that part of the trim; they squeeze into slits in the floor. Careful when popping out -- clips are metal, trim is plastic
- clips might remain inside metal floor -- use needlenose pliers to remove
2. loosen the B-pillar trim, but do not attempt to remove completely
3. from under B-pillar trim, push button and electric clip out from inside.
-use spare tools to keep space under B-pillar trim open
4. Remove top portion of button
- it's either brown or black
- 2 plastic edges on either side clip it in place -- need to loosen both
5. Replace with new button and fit inside trim
6. Replace trim as before
- note that floor trim is very flexible
- metal clips are moody and some like to slip
- get dirt out while the trim is off
- clean under seat
7. Test button and remote
Good luck!
-=K=-
1.Tools:
-needlenose pliers
- clean under seat
Good luck!
-=K=-
Bastid
07-03-2010 06:48 PM
