Tiptronic problem
Old 01-26-2009 | 03:31 AM
ramses's Avatar
Angry Tiptronic not funtioning correctly
Hi guys, I have a little issue with my tiptronic on my 03 4.2. When in tip mode sometimes when I try to change gears it doesn't want to do so. I have to move the shifter around a couple of times or put it back into drive and back into tip mode again to correct it. And again after awhile same thing over and over. Any suggestions. Oh, BTW this happened after I replaced the shifter **** on the transmission.
Old 01-26-2009 | 12:31 PM
nemohm's Avatar
What did you made to replace the shifter ****?
You have disturbed the well being of the tip shifter switch!
Reconfig-adjustment is needed (unless you are due for replacement).
Bentley has plenty of info - be cautious as there might be inaccurate data. (as always with Bentley)
abiv95
05-20-2013 06:27 PM
kuven0107
12-09-2011 06:40 AM
Dadan
B7 Models
12-06-2011 05:30 PM
QuickQuattro
06-26-2007 08:56 PM
bAyArEaTQ
01-24-2007 10:25 PM
