Timing belt replacement--> burning oil smell --> noxious exhaust smell
Old 12-27-2008 | 11:38 PM
seanpawn's Avatar
Default Timing belt replacement--> burning oil smell --> noxious exhaust smell
gggggggggggggggggggggggggggggggggggggggggggggggggg ggggggggggggggggggggggggggg
Old 12-28-2008 | 02:55 AM
gmatov's Avatar
When it's warmed up enough to give you heat, lift the hood and check to see that the rubber gasket is in place across the rear of the engine compartment that the hood seals against. Check too to see that there are no kind of plugs/caps out of their holes in the firewall.
No fumes from the engine compartment should reach your heater air intake. There shouldn't BE any fumes from the engine, unless you have an exhaust leak or oil leak that is hitting a hot surface.
While you're there, look to see if you can find the source of the smoke. Hard to do with these cars, everything's shrouded in plastic.
Hey, if they wrote 1 year, you GOT 1 year. I'm sure you have had something break 1 day after the warranty expired, you are SOL. You're a month under, you got a month to go in which they are liable.
Cheers,
George
Old 01-09-2009 | 08:11 PM
seanpawn's Avatar
Old 01-10-2009 | 04:50 AM
chefro's Avatar
Thanks. Good thing you found the problem.
Old 02-10-2009 | 01:18 PM
TonyTone5390's Avatar
Originally Posted by seanpawn
Well if anyone's curious the problem was due to the "breather hose"
"Breather hose"? is that the PCV system?
Just trying to see if that's my problem as well.
Old 02-10-2009 | 02:26 PM
optimaPlus's Avatar
It sounds like you should get back to dealer who really did the job. I know it's hard to convince but the best way would be to show them an invoice describing job details and cause of the problem.
spikezone2004
05-05-2012 01:01 PM
fourringking
01-13-2012 04:16 PM
fourringking
01-12-2012 05:03 PM
moeron7
11-08-2010 02:32 AM
batoradaudt
03-06-2008 12:30 AM
Quick Reply: Timing belt replacement--> burning oil smell --> noxious exhaust smell
