Timing Belt Job - Bolt Torque Specs
Anyone have the torque spec levels for the following bolts:
Cam shaft sprocket bolt
Crankshaft sprocket main bolt
Timing idler pulley bolts
Timing tensioner bolts
Thanks.
2000 A6 2.7T Quattro.
Thanks.
Toothed belt sprocket to camshaft
55 Nm
Idler wheel
45 Nm
Toothed belt tensioning roller
20 Nm
Pulley to crankshaft
20 Nm
Toothed belt tensioning element
10 Nm
Central bolt 1) to crankshaft
200 Nm + 180 ° 2)
Copied from the Bentley
55 Nm
Idler wheel
45 Nm
20 Nm
20 Nm
10 Nm
200 Nm + 180 ° 2)
Torque Specs
Camshaft Sprocket Bolt 55Nm (40 ft-lbs)
Crankshaft Sprocket Bolt (Main) 148 Ft-lbs + 180 degree additional turn
Timing Idler Pulley Bolt 20 Nm (15 ft-lbs)
Timing Tensioner Bolt 20 Nm (15 ft-lbs)
Thanks Guys! I thought I'd have the crankshaft seal today, so I could start tightening things up but it didn't show. Maybe tomorrow. Cam seals & valve cover gaskets just arrived.
So, probably both of you are pulling torques from a manual, right. Do you have service manual or repair manual? I've read that repair manual has much more info & is the better way to spend the $. But currently I have neither, so I appreciate info from folks like you. I've only found used service manuals & had been hoping to find a used (cheap) repair manual, but it seems like they're hard to come by. I haven't seen either in detail to judge for myself if the repair manual is better. For now, I'm in no rush, so not willing to buy new...yet. Thanks again.
i see the answer that 02A6Beau wrote. Does the crankshaft bolt really mean 200 nm plus an additional 180 degree turn? But the answer to you is anything that has to do with the timing belt, crank, idler pulleys, tension-er pulley, water pump. I' was surprised that that manual I got off of tradebit didn't have any torque specs in it.
Crankshaft torque ?
Hey CRUBY, Do you or do you know anybody that has torqued the crankshaft bolt on a A6. I torqued it to 148 ftlbs, then attempted to put the additional 1/2 turn on it. I was able with the assistance of a friend was able to give a 1/4 turn more, I was afraid that the crank lock pin might shear (the crank looked like it was attempting to turn). I checked to see how much the torque increased using the torque wrench and found that with the 1/4 turn more the torque increased to 250 + ftlbs.
