Step by Step Secondary Air Pump Removal 2.7?
Old 01-22-2013 | 01:47 AM
metalmulisha's Avatar
Default Step by Step Secondary Air Pump Removal 2.7?
Does anyone know of a link on how to get this pump out on a 2.7t?
Thanks
Old 01-22-2013 | 06:51 PM
retho78's Avatar
WRITEUP: 2.7T Secondary Air Injection SAI Pump rebuild - AudiWorld Forums
There's one bolt on the side that hold the pump bracket and it's pretty hard to get too.
I got mine out and replaced both bearings and it runs really smooth and quiet.
If you plan to replace bearings then here is a quick tip....
To remove the bearing plate by the front of the shaft I just used a fine (800-1000 grit) sand paper and sanded a little around shaft area just enough to slide the plate out (only sand right below the thread area). Then remove bearing and install in reverse order.
Thanks.
Old 01-25-2013 | 03:53 PM
I have the replacement pump and just want to swap them out. Do you remove the bracket with the pump attached, then replace? Or just the pump from the bracket? Do I have to remove the silver Y intake to get the pump off? Thanks.
Old 01-26-2013 | 02:33 AM
nobody?
Old 01-26-2013 | 09:55 AM
retho78's Avatar
Yes, remove the Y pipe so it'll be easy to access the pump. You can try taking the pump out without the bracket but may be hard to slide the pump out. It's easier to get the whole thing out. The only issue is the bolt on the side holding the bracket.....it's a pain!!!
Old 01-26-2013 | 04:25 PM
Ok great and thanks, gonna tackle this tonight. The Y pipe fairly easy to get off?
Old 01-26-2013 | 09:29 PM
Ok Pretty easy Y pipe removal, where is the 3rd bracket bolt?
Old 01-27-2013 | 12:16 AM
Never mind, found it. Its in and working. Thanks for the help.
Luc
12-05-2012 09:04 PM
triplerr
05-10-2008 05:52 PM
canmaker
08-23-2007 10:52 AM
Pablo_Ottawa
07-01-2007 03:31 PM
Quick Reply: Step by Step Secondary Air Pump Removal 2.7?
