Setting time and Owners manual
Hi Guys. I bought a 2002 A6 Quattro on Sunday, and I did not get an owners manual. Theres alot of things i need to figure out, but changing the time is the first and most annoying. How do i do it?
RE: Setting time and Owners manual
Pull out the **** closest to the time display, the hour should flash, turn the **** left or right to chang the hour. For the minutes, pull the **** again untill the minutes flash and set to correct time. If you keep pulling on the ****, you can also change the date/ year. When finished, push the **** in again.
