seat heater slow to warm up
Old 12-02-2008 | 08:23 PM
Jeffla's Avatar
Default seat heater slow to warm up
My drivers side seat heater takes about 20 mins to reach the same temp that the passenger side seat reaches in about 5 mins.
Any suggestions? I am open to any ideas.
Jeff
In my past Volvo's/Saab's I ripped the skins off the seats and repaired broken wires to fix non functional seat heaters. But I have never had one work, but just take 20 mins or so to get hot.
Old 12-02-2008 | 08:32 PM
afstud6900's Avatar
Banned
mine is about the same thing
Old 12-03-2008 | 12:09 PM
Coors's Avatar
Jeff
Sounds like the element is not fully energizing. Think of a toaster; the element inside is being enerigized, thus creating heat. Cut that element in half and it is not able to produce as much heat as before.
I believe the element is only partially working. Might have to replace the elemnt, if possible
Hope this helps
Old 12-04-2008 | 12:52 AM
Jeffla's Avatar
At least in the Saabs/volvos if the wire was broken at all they did not work. I plan on taking off the seat skin one of these weekends and looking around. I am trying to source automotive electric resistance wire to just replace the whole thing myself. If anyone knows where you can buy such wire let me know. Google only brings me to importing 500ft from india/china.
Jeff
Old 12-04-2008 | 08:08 AM
bob martin's Avatar
If the wire in the seat was broken, the seat would not heat up at all. You need to figure out where the rheostat for the temperature is and replace that.
Bob
Old 12-04-2008 | 12:18 PM
Jeffla's Avatar
Bob
After fiquring out what a rheostat was, I believe you are correct. Now I just need to figure out where it is. Hopefully the Bentley will have it in there.
Rheostat:
# A variable resistor.
# Two terminal variable resistor used to control current.
# An electrical instrument for regulating the amount of resistance in a circuit.
# An electrical appliance used to raise or lower the resistance of a circuit and correspondingly to decrease or increase the current flowing.
# Device used to control the flow of electricity to a soldering iron and thus control the amount of heat generated at the tip.
Old 12-04-2008 | 06:49 PM
bob martin's Avatar
One would think it is the thumb wheel. try swapping your passenger and driver's thumbwheel. Otherwise, the thumbwheel varies a resistor that varies another resistor and you will have to find the second resistor which is probably in the seat.
Bob
Old 12-05-2008 | 12:51 AM
Jeffla's Avatar
of course the rheostat would be the switch. Duh, never even thought of that. I will swap them sometime soon and let you know what happens. I could also measure the voltage at the element on both the driver and passenger side to see if they vary at all.
Thanks for the help Bob
bartusxpl
12-10-2011 09:39 AM
xzera
09-16-2010 11:43 PM
chuck322
01-18-2005 02:47 PM
chuck322
01-18-2005 12:39 AM
