Quick Coolant question.. need help asap!
Old 11-05-2013 | 06:50 PM
GeondrayPeterson's Avatar
Default Quick Coolant question.. need help asap!
Hi I have the 2.7t it takes the pnk coolant g13 i believe i cannot get any now.. the car is running on water it should freeze tonight will it harm my car any if i put green coolant in there? the peak 50/50
Old 11-05-2013 | 07:18 PM
Nebuchadnezzar's Avatar
Audi doesn't advise using anything but G12 or G13. I suppose you could put green in there and flush the system several times in hopes of getting all of that crap out. I certainly wouldn't leave it in there for a long period of time. Oh, and make sure the system has been purged of all G12 or G13 coolant prior to adding green stuff.
Or an alternative would be to drain the system tonight and let it sit empty and then refill tomorrow prior to use and then drive to get the proper coolant.
Old 11-05-2013 | 07:51 PM
OGBULLYLOCDAWG's Avatar
Do not mix the green coolant with the G12/G13. From what I've read they react negatively when mixed and turns into a chocolate milkshake like substance.
That's a good suggestion by Nebuchadnezzar. Drain it. Refill in the morning.
Where is the coolant leaking out?
Old 11-05-2013 | 07:55 PM
Also, do yourself a favor and mix it with distilled water as tap water or spring water will contain minerals that may allow the system to rust / deteriorate over time.
A4Cragman
04-17-2011 06:02 PM
nova_ss672001
10-19-2010 09:24 PM
juice88
07-13-2006 03:23 PM
jimmysA4T
08-26-2005 04:10 PM
CaliA4
03-31-2005 02:28 AM
